Still mowen in Ct
BX 1870,Mowing 54 inch belly,FEL for snow and fire wood hauling
Greetings,
Been lurking since 2014 did a search cant find specific bx 1870 instructions for Fuel Filter replacing and bleeding if required.
Dealer did the 2nd filter at 50 hrs here under warranty agreement for other problems.
I didnt see the tech do it at 50 hours.
Now close to 500 hours.
Decks ready to be put back on for the season and b4 I do it I want to replace any thing up under there. Hydraulic and fuel filters, oil too.
I notice the protector plate for the HST Fan and looks like it needs to be dropped.Rest looks pretty clear and will need to pinch inlet to the filter to stop the flow.
Will I need to bleed the lines after I replace both filters?
Is there a bleader valve for all 3 injectors or do I need to do them individually or at all?
Any guidance and or OTT links or to you tube would help.
Found a link to youtube years ago but lost it.
Getting old and only want to go under there 1 time
Thanks in advance for any tips and input
