BV4160 baler net problems
Terrible
B-3000, M-108, M-135GX, BV4160, etc.
Jun 5, 2019
Greene Co. MO
Running a 4160 and the knife has stopped tripping (cutting the net) The auto tie does start the net. It is set for two wraps, then it should cut the netting. The knife stopped tripping about 20 bales ago. It just keeps wrapping until the pto is shut off. Then I have to dump the bale and get out and cut the net with a pocket knife.
I took the baler in for service and to have it checked out this spring. It wouldn't start the auto-tie last fall, the last field I baled. I was able to get through it by punching the manual start a couple of times for each bale. I knew that was because of trash build up in the baler interfering with the mechanism. That happens about every 200 - 300 bales. The trash builds up in places that are hard to get to and you need different tools and utensils and a compressed air blower with a long reach to get it out. Not something you can do in the field.
I got it back from the dealer's shop and it worked great the first five bales of the year. Then it stopped cutting netting. The baler has about 12,000 bales through it and this is the first time that has happened. I messed around with it for a couple of hours then called the dealer. They sent a technician out and we worked on it for about four hours trying different things. The sensors all tested good. Since I had hay in windrows we were able to test each adjustment. He got on the phone with "technical support" but it was a Saturday and they were looking up solutions on the computer. The technical expert was off for the weekend. The mechanic had been to kubota's baler school and he had a detailed repair manual but it did not address this problem and he said he couldn't figure what needed adjusted. He got up in under the inside and found some more built up trash. In the process of clearing that he cut his hand pretty badly on the knife. After a round of cycling the tying mechanism several times with the monitor I tried one more bale and it worked. He stayed until I successfully baled half a dozen bales then he left. As I finished up the field it malfunctioned on the last bale.
You set the number of wraps of netting you want on the monitor. A counting (measuring) wheel rolls on the net roll as it turns and counts the progress of the wraps on the monitor. When the specified number of wraps are completed the knife trips mechanically and cuts the net. The monitor then gives you a signal to dump the bale, etc. That is the way it is supposed to work anyway. The net measuring wheel has a magnetic sensor on it that counts off when the net is rolling. It is sending those signals through the wiring harness to the monitor inside the tractor. The monitor shows those wraps as they occur. Then it sends the "cut" signal to the knife mechanism. I have learned to listen carefully for the "clunk" of the knife. The knife trip mechanism is all mechanical except for an electric motor mounted on top that resets or re arms the spring loaded knife in preparation for the next cut. I can't see how it would trip the knife but the motor is the only electrical device on the netting mechanism. And it has to be causing the knife to trip some way and that signal has to be coming from the monitor because you set the monitor for the number of wraps you want on the monitor. I am thinking it is an electrical failure in the wiring harness or monitor or netting actuator motor. Like I said earlier, the sensors are all showing good.
Anyway, three days and I can't get a call back from the dealership. I have 230 acres of hay in two different counties that need to be cut and put up last week and we are in a weather pattern where it is raining every six to thirty six hours and has for the past month. But that is just farming.
What I am hoping for with this long winded post is to find someone who has dealt with this net cutting problem and can tell me that it is a simple fix that I just haven't seen.
Thanks guys
8,202
Have you download or gotten the manual and read it?
Have you checked the adjustments for the cutting knife?
There is an interlock on the gate that if the interlock is out of adjustment then it won't cut.
And yes the manual states it several times what to do to keep from being cut by the knife.
SidecarFlip
Banned
557
Is a 4160 a Kubota bailer? I have a New Holland 460 twine and net and my wrap mechanism is controlled by a linear actuator as is the knife reset. The trip function is a result of the linear actuator moving just enough to engage the notch in the cam plate and allow the knife to drop (spring loaded). To date, my only issue has been trash getting into the duckbill and causing the net not to run full width. I run 52" over the edge JD (Tama Net). When I experience a net issue I just switch to twine and keep going.. My 450 runs 6 different twine wrap sequences and any number of net wrap sequences, all set on the monitor, plus I can change on the fly if I want to.
I would never consider a round baler without both twine and net.
If it's a Kubota baler, how do you like the in cab electronics? My dealer wants me to demo one but I don't much care for the monitor. The New Holland monitors are light years better from what I see plus the NH monitor has built in self diagnostics.
Never had an issue other than trash in the duckbill and then, like I said, I switch to twine (my 450 holds 4 mega balls.) and keep on trucking.
SidecarFlip
Banned
557
You'd darn well keep clear of the net knife. Same with n=my NH450. it's razor sharp.
c3group
BV 4180
Jul 9, 2021
Tulsa
Thanks guys
Did you ever find a solution? My baler is telling me the net needs fed about every bale. When it does finally feed and wrap the knife isn’t cutting. I’m getting E63 on the monitor.
cbuffer
baler
Aug 5, 2021
arkansas
Did you ever figure out how to fix this problem? Mine is doing the same thing.
5,393
2,082
for reference, Kubota doesn't make them--they are made by Kverneland, Kubota bought Kverneland a few years back.
The manuals are as clear as mud.
c3group
BV 4180
Jul 9, 2021
Tulsa
Yes, I took it in and they said the knife had adjusted out of place and they adjusted it back. I've only baled about 45 bales since they fixed it and I'm baling more today so I am hoping it is fixed for good.
