bucket operation b2630
kubote
Maine, USA
I think I overloaded the control valve while running my bucket. It still works, but not quite like it should. I can't move the bucket arms up and down while also moving the bucket itself up or dump. I believe it is a yw248-00102 (or 00100). I don't want to spend two grand to find out if I'm right. Can this be rebuilt? Should I be looking elsewhere for the problem?
4,933
1,664
yes they can be totally disassembled and repaired. Kubota offers (or used to...I haven't been into one in a while) most of the parts for the valve assembly. What loader model is it?
1970cs
1,124
Grand Ledge
The LA403 has a serial number break. So when ordering a detent kit have your serial number handy before ordering.
Pat
kubote
Maine, USA
Thank you both for your replies, this is quite helpful. To answer, it is in fact an LA 403.
Is a rebuild something a novice can do? I'm not mechanically inept, but probably wouldn't rebuild my carburetor.
ibunker
B3300SU w/BK76, Box blade, DR wood chipper
Dec 5, 2010
52
Port Orchard, WA
You may want to check your hydraulic quick disconnects going to your FEL. My problem was I could not raise (boom up) my bucket. Switched hoses around, the bucket boom and curl hoses. Now I could raise the bucket but not curl. I reconnected the hoses to the original configuration. I removed the male nipple of the boom up with the boom down and now the bucket would raise but not lower. I spent $10.99 for a male nipple that solved the problem. The pin in the nipple is depressed some and off center.
kubote
Maine, USA
Oh, thanks. Definitely worth looking.
Tooljunkie
May 13, 2014
4,150
31
Not your three point lever pulled up and deadheading. Been caught there before as well as auxillary hydraulics inadvertently activated.
Got me a few times, from getting on and off tractor and nudged lever.
