So here's what I created for a bucket level indicator. Did this back in the summer but just got around to taking pictures.
The first two pictures show the part I fabricated and attached using an existing bolt. I made it by bending a piece of flat bar into a U shape around that connector bar (not sure what it's really called), then welded another piece between the legs, and a piece of round bar onto that piece.
The third picture shows the connection to the loader arm using existing holes. That's a 3/4" nipple, and I can unscrew it for easy removal.
The smaller pipe is 1/2" and slides in a 1" pipe. I probably should put a short piece of 1" on the other side of the tee also, but anyway, I just use the tape and when it gets to the edge of the tee I know the bucket it level at the ground. I can also just add another wrap of tape if I need it for the forks, or even if I want an indicator for level somewhere other than at the ground. And if it breaks, it's cheap to fix.
