Brush Hog Slip Clutch
CAPT Seabee
Grand L5460
Dec 28, 2022
92
91
Bonners Ferry ID
I have a L5460 which a quick hitch is used to grab a RCR 1272 Brush Hog. It originally had the Grade 2 shear bolt. Problem is, unlike my now gone JD 1025R, the PTO isn't a soft engage. The brush hog has lots of inertia. Even at idle, I'd get a slam on engagement. Around ten times later, the shear bolt would be toast. BTW, much of the drive shaft shrouding creates unsafe conditions when trying to lube, replace a shear bolt, etc. So for around $208, a slip clutch was installed using Grade 5 shear bolts on each end. It's a two person job because of the unsafe shroud that severely limits access. My son made the difference. Now I still engage at idle, but there isn't the "slam". It's getting smoother as the clutch wears in a bit. Bottom line, makes life work again. Kubota instructions says Grade 8 and Grade 2 shear bolts, but the dealer said just use two Grade 5's and I'm good to go.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Are you transporting passengers on the brush chopper? If not, I'd remove the guard and make your life easier.
SDT
Apr 15, 2018
3,683
1,408
Bingo.
That's the problem with most indepent PTO clutches. No way to feather engagement.
SDT
Apr 15, 2018
3,683
1,408
Shaft will wrap-up with grass, weeds, etc., in many conditions.
hoobie
mx5100
Aug 11, 2020
14
canada
My mx5100 hydrostatic trans tractor has a main clutch as well. I shove the clutch with my left foot, then engage the pto switch at idle, then feather the bush hog up to speed letting out the main clutch with my foot. Pto won't turn until the main clutch is engaged.
