Well flushed with success using my short 3 point mounted small crane using my 2500 lb HF winch I decided to use my previously fabricated rear fork set and make a boom crane for the same winch.
As you can imagine using a small winch is a limit but it is only for lifting theMMM, front snowblower and probably log lengths of wood. I am not looking to or want to lift anything that I deem dangerous.
The basis is my forklift, this will give me a good base with the forks acting as outriggers. It attaches to the tractor using a channel section over a drawbar and sits on the ground when fully down.
I have used thick walled 2x2 square section as the post, I have inserted a smaller square section inside to act as a locator and jointer, I want that removable when not in use so it has a bolt which can be removed.
As the two sections, the one fixed to the forks and the post are the same section any download will be full contact. I did place a section at the bottom to offer an extra area of frontal support although not necessary as it is held on the same plane with the top link.
I have included some construction pictures. The welds are not aesthetically great but they do have full heat penetration, which is what I was looking for.
While I was waiting for the welds to cool I installed my new tool box. Located in place of the Kubota sandwich box. It is removable with two pins and clips to the powder coated angle they sit on. All parts that were lying about in the shop.
Sorry, the pictures are wrong, I tried everything to rotate but they just keep doing this.
Comments are always appreciated.
