Bolt Size
In Utopia
L175 FEL
Apr 21, 2013
640
157
Utopia,Tx/Pasadena,TX
Just picked up L175 with a FEL.
Neighbor came over and looked at it today and said there was a bolt missing on the side and rear of the FEL framework.
Now the hitch, I'm 300 miles from it, won't be back there for about 10 days and 54 miles one way from the nearest Metric bolt selection.
Anyone have any idea what size it might be? He says about 3/4", but really doesn't anyway to really know.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Its hard to say for sure without knowing the manufacture of the loader. Even identifying the make can be a long shot in the dark if the labels and decals are worn off.
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Quick. Have him remove a similar bolt and mail it to you since you have ten days. Swing by the hardware store in the way up and you should be golden.
In Utopia
L175 FEL
Apr 21, 2013
640
157
Would ask him to do more, but he's almost 90 and doesn't really get around much.
What I did get from him was the bolt looks like it goes into an existing horizontal hole in the tractor close to the bottom, and near the end of the loader. I think he was trying to tell me it's behind the vertical square piece where the cylinder meets it, but lower.
Maybe this pic will help with the missing bolt, and to ID the loader. Been curious about the make, and didn't have time to research it last trip up there.
In Utopia
L175 FEL
Apr 21, 2013
640
157
OK, I'm giving up on the bolt till I get back up there.
Anyone have any ideas about the FEL?
Last owner (second owner) said that's the way he bought it.
Orange Tractors
L175 w/Woods L59, Allis Chalmers WD
Jul 19, 2009
323
Butler, MO
I don't have any idea about the loader, except that I sure would like to have it.
At a wild guess, the bolts are probably 12 or 14 mm, but I don't know how long or the thread pitch. Might be cost effective to buy a small selection.
Robert
In Utopia
L175 FEL
Apr 21, 2013
640
157
Robert
That's what I'm going to do today. Length is no problem, I can always cut them off.
Price ($750) and loader is the reason I bought it. Have no use for the shredder, so I'll be selling it. Great deal for someone, it's like brand new except it sat out in the weather for years.
Stubbyie
879
Midcontinent
Don't mean to rain on your parade, but you say the previous owner bought it and used it like that with the bolt missing.
Have bought and sold a few with FELs and have learned the hard way...
Start thinking how to proceed if you find that bolt sheared off. I've seen it more than once.
Good luck.
Please advise how you resolve and post back that we may all learn.
In Utopia
L175 FEL
Apr 21, 2013
640
157
Not a problem, removing broken bolts is one of my strong suits, removed hundreds in a previous life.
Sent from my iPhone using Tapatalk 2
Stubbyie
879
Midcontinent
I'd appreciate your elaborating about how you remove broken bolts. I'm interested in learning more than I know.
I've had reasonable results with drilling followed by varioius styles of EZ-outs and a few larger ones using a welding electrode (called X-Tract) weld-a-nut method that seemed to work if directions were followed exactly. And a few spectacular failures. Which prompt me to ask about your expertise.
It's one thing if the part can be chucked into a lathe, but significantly more interesting if working on something like a tractor chassis.
Thanks in advance for sharing your expertise for the benefit of all.
In Utopia
L175 FEL
Apr 21, 2013
640
157
Started in 1962 as a production machinist and that's where I first used a tap disintegrator. Lot's of broken taps in a big shop like the one I started in.
Moved on to maintenance machinist in a cast iron foundry. Used mostly torches and welded nuts there.
Maintenance machinist in can company, mostly drilled them to body drill size and either pulled out the old thread or ran taps in. Very little welding allowed there.
Became a millwright. Lots of broken bolts there. Mostly drilled out, sometimes heat and tapping with a punch got em.
Back to maintenence machinist in a plastics plant. Again mostly drilling and an occasional nut welding job. Getting hot work permits in that invironment didn't happen often.
Then I retired.
Now it's a no holds barred. Just any way I can.
Success rate with any type E-Z out was never high with me. Broke as many of those as I did taps.
The new one for me is now the Extracalloy, never tried it, but it looks like something I really could have used over the years, thanks for mentioning it. Just called, ouch, $58 a pound, five pound minimum. Sure would have like to tried some.
Don't know what I'll find when I get back up there, still have a lot of irons in the fire, so if it's a rattled out bolt (which I'm hoping for) I'll be tickled and use the loader right away, if not got to get a new CNC plasma cutting going first since it means income.
If not rattled out, it's probably sheared just below the FEL loader mount, so that's a whole new ballgame.
In any event I've got a couple of different metric bolts ready and I'll keep you posted.
Almost forgot, last boss told me he never knew a lathe could do so much.
Stubbyie
879
Midcontinent
Please keep us informed of your progress and what you find.
I've always tried to keep in mind that in theory the lathe is the only machine tool that can reproduce itself. Our little SB toolrooms are used in self-defense to prevent having to beg a real machine shop to take our money and do our work to our standards and then wait wait wait.
Try calling ExtracAlloy (sp) and asking for a sample of a few sticks. Post your results on here and tell them you might be able to gin up a few more sales to the community. I've had good luck over the years finding the right person with a sympathetic ear that might spit out a sample occasionally. Never hurts to ask.
In Utopia
L175 FEL
Apr 21, 2013
640
157
Tried sympathy for samples, didn't work, put on the best charm I had, joked with the nice lady, even had her laughing, said she could not do it.
Sure would love to try them.
Battered Sav
L2000DT (L225DT) Tiller, Slasher, Finishing mower, Ripper, grader/ripper, PHD.
Oct 1, 2012
65
Melbourne Australia
Having bought a few bolts (and a recoil kit) for my tractor, keep in mind that the thread pitch may be metric fine.
