My tired little B7100 has more blow-by than ideal. When things cool down the fall, I may determine if it's the valves or rings and rebuild it IF it turns out to be an otherwise worthy little tractor. But it still runs fine for now, and in the mean time, I would like to get a bit more control on the blow-by.
It appears that there is a vent tube attached to the top of the head on the forward end just behind the water neck for the upper radiator hose. It's quite stiff, goes down the front, and disappears under the starter. I'll have to pull the hood and side panel to see exactly where it goes. But just below that I get quite a bit of engine oil running down on the FEL frame and dripping all over the place. I don't mind the tired paint, or the dents, or any of the various cosmetic blemishes. I want a tractor that does work I need done, period. But I can't stand that kind of oil mess.
So the main question, is that the vent line like I think it is. If so, I'll just run it down clear of the FEL frame so it can drip from one location instead of over 4 square foot area as it builds an ever larger clod of oil/dirt grime.
