I have a mr4800 mower and have broken 1 blade. The blades that kubota recommends will not fit. Messick is trying to find the correct blade, but so far has had no luck.
Does anyone have any info?
Kubota says the blade is Part # 70000-25006, but it is 20 1/4 inch long and has no alignment holes. They say I should remove the aligment pins on my mower deck. The problem with that is, the blades on my MR4800 is only 16 1/4 inch long, 2 inches wide and has an alignment holes on each side of the install hole in the center.
Any Help??
Thanks
Any Help??
Thanks
