Big boots catching on HST pedal
DaveMueller
L3800HST TLB, LA524, BH77, Ford 917L
Apr 16, 2019
24
Mill Run
My size 12 work boots are a perfect fit to catch under both front and back of the HST pedal when I'm getting out of the seat. I'm afraid one of these days I'm going to do some real damage to my right knee because I have to twist to get out (I'm 6'-2" and mostly legs).
Has anyone fabbed a pedal that's friendlier to big boots?
Thanks
Dave
BigG
Sep 14, 2018
1,951
773
West Central,FL
I saw where someone placed a piece of metal plate on top of the HST pedal and bolted on. He fabricated some thread on top so his foot would not slip. His foot did not touch the running board between the two pedals. And he could unbolt it if he was to sale the tractor. The new pedal was bent down in the middle but since it was on top of the original pedal his boot no longer got caught under it.
Hope that makes sense.
5,572
Everyone with a BX23S gets a left leg workout using the brake pedal ! It's way too far away from the floor......
I like the 'bent-plate-fwd-rev' idea...might look into that....
DaveMueller
Apr 16, 2019
24
Mill Run
I like it. Maybe either a piece of diamond plate from Tractor Supply or flat metal and an anti-slip tread from Harbor Freight...
KHW59
L-3901 Brushhog, Finish mower, road planner, box blade.
Apr 28, 2016
59
Palatka Fl
Thanks
Dave
I fabed this up to accomindate my size 13s. Also makes it easier to use reverse by just hooking the toe underneath.
rokhunter
BX23S TLB
Dec 28, 2018
90
Baker, Florida, United States
I don't touch the left pedal unless I'm setting the parking brake. If the tractor doesn't come to a quick stop when the HST pedal is neutralized (aside from a steep slope and/or carrying/towing something heavy), then something's out of adjustment.
Sent from my Pixel 2 XL using Tapatalk
powersrp
B3350
Apr 2, 2017
94
Indian River MI
i struggle also, 6’O, Right knee replacement was a flop, so i struggle even pulling up the pedal for reverse, and my knee wont bend far enough to use the reverse as its made. sumhow i need to extend the whole pedal.
BigG
Sep 14, 2018
1,951
773
West Central,FL
i struggle also, 6***8217;O, Right knee replacement was a flop, so i struggle even pulling up the pedal for reverse, and my knee wont bend far enough to use the reverse as its made. sumhow i need to extend the whole pedal.
We have a poster on this forum that is wheelchair bound. He attached a plate from the front of the pedal to the rear of the pedal. He then fabricated a handle and welded it so he can push it forward and pull it back to move his machine. I am sure you could do this so that you could go forward with your foot and pull it back by hand.
Check this thread out: https://www.orangetractortalks.com/forums/showthread.php?t=45850&highlight=boot
powersrp
B3350
Apr 2, 2017
94
Indian River MI
Im actually going to look at the cruise control lever for controlling reverse. Actually i was under the tractor today and noticed the threaded rod linkage going from pedal to cruise control lever. It may be possible to make it push for reverse versus pulling to go forward as it does now. Hmmmmm[emoji851][emoji848]
