BH92 Cylinder VERY HOT!
15FoxRzr
2017 MX4800HST BH92 Backhoe LA1065 FEL
Dec 11, 2017
19
Templeton, California USA
after using my BH92 for about 30 minutes the "Dipperstick" cylinder is so hot i can barely hold my hand on it. Is this normal operating temp? also i'm running the RPMs around 2K. :confused:
3,097
Very normal....you would be hot too - if squeezed under pressure and pressed through a fairly small hole back and forth .....thousands of times! :D;):)
7,383
Oh boy....couple weeks ago greeno had a hot rear-end and now a hot ram....
Let’s keep it PG-13 or better....[emoji12]
Seriously, as the guys said, a bunch of heat is generated with hydraulics.
I think Kenny said rule of thumb is 100 degrees F above ambient temperature, so it can be very hot indeed.
