Best position for bucket hooks
Sobrbiker
‘87 L2850 w/BF550 and MF-18 72” box
Aug 19, 2023
40
14
Casa Grande, AZ
I use mine to chain all sorts of things to bucket, or even use the hank of muletape I keep in toolbox to secure things.
Most recently used them to support my el cheapo bolt on forks when I had to unload horse panels by myself that were delivered in stacks of up to 800lbs.
Used chains to keep bucket from smiling.
Testing the forks with water to see how much I could lift with the BF500 (rated 1100lbs at bucket pins-a lot less with load 4ft in front of pins). Wound up close to maxing out at around 625lbs).
I got one stack from truck onto my trailer but the rest went on the ground because as system got hot, my capacity went down.
not bad for one old guy and an old L2850 (sure beat unloading 50 panels and gates manually one at a time at 60-90lb each😉
L45/X1120
Mar 19, 2025
21
24
NM
These were on mine when I bought it new. They were welded on before it was painted. Not the best place. If I try to pick up something heavy the asymmetrical rear wheel will come right off the ground. Don't put them where these are.
Sobrbiker
Aug 19, 2023
40
14
Casa Grande, AZ
I’m assuming by “asymmetrical” you mean the tire on opposite corner.
To lift from center of bucket-You can get two chains (one with hooks) and drape one across both your hooks, then hook another to the center of that chain between hooks and to your load, centering load.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
84
Waterford, Maine
Typically, weld-on or bolt-on, each hook directly in line with each loader arm.
Sometimes a third hook in the center, but that causes the formed lip at the top of the bucket
to carry the load to the loader arms and then it is easier to deform the top lip of the bucket.
If you add a bolt-on hook in the center, they are available with a reinforcement plate with a vertical
"tab" for attaching a clevis. (at the top of the FEL bucket, but inside the FEL bucket)
Oversize inside the bucket reinforcement plates are available for some models at the below link.
You didn't mention if your bucket is "pin-on" or "SSQA", but this place has both options.
This link is for a "SSQA" FEL bucket.
I put two hooks on my bucket, directly in line with the loader arms.
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
Had my dealer weld on two hooks to the FEL bucket before taking delivery of the tractor. Welded inline with the loader arms. Hooks were like $5 each and they welded, sanded and painted them at no charge since I just purchased a tractor and a few implements from them.
they have been invaluable. Paired with some truckers chains with hooks on the ends, I've been able pull, drag, lift and carry some pretty sizable rocks and stumps. Makes the FEL so much more usable they should be standard equipment in my opinion.
