Well, today was a real highlight moment.
After a fall of 6 inches of light snow, I decided to blow it using my twice used new front blower. All went well at the start and it did a good job, however, as I approached the 25-minute mark and blowing just 6 inches of snow the universal coupling at the PTO drive end let go, snapped and sent the shaft flying.
Well. it flew into the cross member, then left the snowblower coupling.
It is a horrific noise and then you think what happened as you drive over the shaft lying now behind you.
Snow blower is fine, all shear pins intact rotates easily by hand, PTO splines are ok on both blower and tractor.
So the damage is to one universal coupling, one of the cups is completely missing, the other is sheared off. Tube, is bent with a good sized dent.
Anyone else had any issue with this blower? It has operated for about 1 hour, installed by the dealer.
