L Lblevins Member Equipment Kubota L2200, John Deere 1050, Kubota L3301 with woods bh80x Sep 1, 2017 48 1 6 Ada, ok, USA Jun 14, 2018 #1 Has anyone added a belt driven hydraulic pump for a fel or backhoe attachment?
1 100 td Active member Equipment B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat Aug 29, 2015 1,776 9 38 ɹǝpunuʍop Jun 14, 2018 #2 You'll have a job and a half getting enough belt/s contact to provide the power without slipping. https://www.ebay.com/itm/253136139133
coachgeo Well-known member Equipment L225 w/woods Few Mowers & Back Blade, D722 in Motorcycle (Triumph Tiger), LMTV Nov 16, 2012 2,459 37 48 Southern OH Jun 14, 2018 #3 many of the older models you could put a pump on the shaft at front of engine. Direct drive using I think a chain coupling. Pump sits in the gab between front sheet metal and bumper?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,080 11,042 113 Sandpoint, ID Jun 14, 2018 #4 Lblevins said: Has anyone added a belt driven hydraulic pump for a fel or backhoe attachment? Click to expand... Yea buy a SSV or a SVL then you have a Kubota that uses a belt to drive a pump. A normal belt driven pump would never work, not enough GPM or PSI.
