Battery Tender acting silly
5,589
Ok yesterday I stumbled into the garage, from the fact that what ever has got a hold of my chest aint lettin me breath to well and I feel worse after takin the meds than I did before,, Anyway the tender I have on the Bouta was blinking yellow,,Its always red when disconnected yellow while its charging and green when full charge,,, I have never seen one do that before, and dont have any idea why,, anybody ever seen this before???
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Look at your manual? What charger is it? I'd assume that means there is a fault, bad connection, problem with the battery, charger problem, ect. But you won't know for sure without looking it up.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
10
Richmond Va
Is something on the tractor still left on, like the key isnt turned off all the way and the battery is putting out a constant power.
birddogger
433
Pittsburgh
The way mine works is it blinks or flickers yellow for a moment every 5-8 seconds or so. That indicates the battery is fully charged and it pulses ever so slightly to make up for the self-discharging (which is why you use a tender/maintainer).
5,589
Nope thats not it,,, if i disconnect it the light goes red,, yellow when its charging and green when its done,, I looked but there is nothing on the tender or in the limited directions about it blinking. Oh yeah its a SEARS tender. I think you might be onto something there about the key turned or
something else. I tryed hitting the key not starting but like to the glow plugs and it started to blink and did so after I released the key,,, I will have to try this again,,,it also resets if I disconnect the leads and re-connect,,,
birddogger
433
Pittsburgh
I take it then it is blinking rapidly?
I use the Sears also. I'd try disconnecting the battery cables to see if that changes the blinking. Then try it on a known working battery.
I had one battery that was working one day and shorted the next.
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
I don't know what brand it was, but I know of a family that lost thier house and everything in it in a fire that was blamed on a battery tender malfxn.
5,589
well I checked the battery 12.8 volts,ok i checked the out put from the trickler charger .003 on my Fluke,, checked the other one onthe harley also a sears but a different mdl,, and 13.8vdc at the plug,,, I think it must have shyt the bed,,
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
10
Richmond Va
Well either my battery maintainer went tits up or my battery is so far gone on my tractor. I've been tinkering around on my tractor the past two days and I plugged in my maintainer last night and went to fire the tractor up this afternoon and nothing. Like usual I had to jump start the tractor to get her going. I've had an on going electrical problem for quite some time. I dunno maybe my dynamo has gone south!
