Battery Replacement ?
tater pop
64
Maud texas usa
My 2008 mx5100 has showed signs of the battery going south this morning it wouldn't crank without a boost. What do I need to look for in a replacement battery?
2,898
Take the old one out ....measure it's physical size on the outside, some battery places have very tight fits;) - go to the store and buy the same size or similar size external shape.....but with the HIGHEST CCA you wish to pay for. Higher cold cranking available amps is what you are looking to buy. Check carefully the warranty.....some word it in such a way that 3 years down the road....they will give you 10% off the price of a new one, some will replace the battery after one year ....and so on!
Charge the new battery before placing too - a sloooow trickle charge not a high amp charge. Many batteries sit on a shelf a bit, thus losing a bit a charge ;)
tater pop
64
Maud texas usa
Thanks for that info I'll stay away from the low CCA batteries.
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
+1 on the previous comments. If there IS extra room, get the biggest battery with the most CCA's you can fit. Also, a battery intended for off-road use (ag, construction) may cost more but, will handle shock and vibration better than an over-the-road battery.
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
Believe it or not. I have a L3830HST I bought new in 2006. It currently has around 700 hours and still has the original battery. I can’t believe it but I just started it it’s in the 20’s now but lows have been in the single digits for the last week. I know I’m on borrowed time
armylifer
Mar 26, 2013
2,244
1,006
Thurston County, WA
When you shop for the replacement battery make sure that the positive and negative terminal posts are on the same side as your old battery. Size is not all that matters.
2,898
+1 on that comment too!!! Aint nothing like GOING BACK to the store again.....to get the posts where you need them!!!:D:) BTDT!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
I've been curious about the quality of the Kubota batteries the dealer sells. My factory battery in my L3000 lasted 11 years but it's used nearly every day.
I put a blue top Optima in my M9000. I love the cranking power but the price sux.
rut3556
TG1860
Oct 23, 2015
116
21
NH, USA
>>I've been curious about the quality of the Kubota batteries the dealer sells.<<
I'd be more worried about the price. I get my replacement batteries at Batteries+.
Oct 8, 2014
616
oregon
Just like oil Kubota doesn't make batteries. Size, CCA's and posts matter but there are batteries and then there are Batteries. I'll be ready for one soon too.
David H
L185
Oct 31, 2016
73
Auburn Hills, MI
Been using batteries that have posts on wrong side but cable still gets there. Just a pain.
Recently bought Duracell battery and AFTER went to their site and found they had my old tractor 1978 L185 listed with the posts where I need them. Too bad I was late looking.
Many good batteries come with 3 year free replacement warranty and 2 year pro rated.
I suggest to buy the biggest and largest CCA.
David
PS my Original battery from Kubota was a Panasonic and it did last a good long time
Most batteries have a group size on them Yours may have and you can just look for that size when you go shopping.
