B9200d tractor came with the 30 acre property we bought. Runs great but it seems the clutch needs to be replaced. The clutch has already been adjusted as far as it will go. It has to be started in gear then shifting is fine. Engaging the pto also needs to be done as the tractor is shutting down and then restarted. The dealer says 12 hours labor plus 500+ in parts. 2k ish. Any suggestions?
