B9200 fuel leak
Mikeb9200
verona, ky
Just replaced fuel filter assembly unit. Thought it was bad. Bought a new one, installed it, it leaks in the exact same spot, right at the seam, at the air bleeder valve at the very top. It leaks at the seam where the quarter inch brass stem is seated into the filter assembly unit. Cannot figure it out for nothing.....please help!!
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Your fuel line could have a linear crack in it. Try replacing that cheap rubber hose.
Mikeb9200
verona, ky
Thanks for the help. To fix the problem, I pulled out the little brass air bleed nipple, threaded the hole and ran a bolt with a neoprene washer. No more fuel leak, no more air in system. She never ran better!!
