B8200 Stuck Clutch
JPB7745
L2501, B8200 and Ford 3000
Aug 27, 2018
52
Okatie, SC
Tractor sat for about 4 months and now no clutch. Was able to crank it in gear and drive around even into a tree a let the tire spin, forward and reverse. Any thoughts
8,591
Do you have a PTO power implement?
If you do run it under a load (working it) with the clutch pedal held down.
You could also try blocking the clutch pedal down for a while, and see if it will pop open on it's own.
Only other real option is to split it and clean the rust off the flywheel.
FYI: Leave the clutch pedal block in the future to avoid this issue.
3,154
When you drove into the tree, did you have the clutch pedal depressed?
Edit; The wolfman beat me to it with better advice anyway...all I had was a question...
5,133
I block the pedals of all 3 of my tractors when I do not anticipating using them for a month or two.
All 3 are always stored inside also!
