B8200 Dash Panel Idiot Lights
wozDaddy
Retired
Mooresville, NC
Me again,
None of the idiot lights work when the key is on. I replaced the regulator, but still a problem. ???
Thank you,
wozDaddy
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
Could there be a ground loose or not connected?
RattleCat
L3450 GST
Apr 12, 2014
Cadott WI USA
I had the same problem on a L3450. The traces on the board had worn off underneath the rubber grommet of the round electrical connector. I scraped off a little bit of the gel coating from the trace with a dental pick and soldered in a piece of copper braid to bridge the connection.
If the easy stuff fails start checking for continuity.
wozDaddy
Retired
Mooresville, NC
Thanks for all your help !
I found the problem. : )
One end of a fuse holder was not making contact. (the fuse was good)
You guys got me going in the right direction.
Thanks' again !
wozDaddy
