b7800
dwildman1946
b7800
Sep 4, 2016
golconda,ilorange
every time I engage the pto or try to move the tractor in any gear it dies. If I just start the tractor and let it run there are not any problems and it runs just fine. any one have an idea on this issue:
3,110
1,243
Sounds like the seat safety switch is not working properly. Checking that when you sit on the seat it pushes the switch in all the way. If it does, then unhook the electrical connection going to the switch and use a piece of wire in the plug to bypass the switch. Then try moving the tractor to see if this solves the problem. If it does, then probably the switch has gone bad and needs replacing.
dwildman1946
b7800
Sep 4, 2016
golconda,ilorange
Re: b7800,dwildman
I put a jumper in on the seat switch and everything worked great , thanks for the info. sure glad I didn`t have to change those muffler bearings.
mendonsy
B7500HST/LA302
May 28, 2012
361
37
Mendon, NY
That makes me really happy that my B7500 doesn't have all that excess baggage, only the PTO neutral switch on those.
3,110
1,243
Your welcome. Glad it was a simple fix. Changing muffler bearings is a bear because they are so hard to find.
