B7800 solenoid
BobbyT27
B7800
Jan 29, 2022
Ontario
New to the forum
is there a known issue with the fuel solenoid? Mine is intermittent. Of course it is bloody cold so not sure if that is the issue. Tapped it with a large screw driver and it worked. Do they need replacing? 535 hours on the tractor
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,053
Williamstown Ontario Canada
Usually the problem is in the controls providing power to the solenoid.
OPC for operator presence controller and timer relay being two most common unless a safety switch is faulty thus triggering the proper operation of the OPC. Seat switch would be first to investigate.
Dave
BobbyT27
B7800
Jan 29, 2022
Ontario
Dave
Thanks.
The tractor turns over though and just will not start unless I hear the click form the solenoid. Will this happen if the OPC is bad?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,053
Thanks.
You need to first understand how the engine stop solenoid operates on your tractor.
Some tractors apply power to the solenoid to allow the engine to start.
Other tractors apply power to the solenoid to stop the engine.
I am not where my resource material is so this is a educated guess.
Your solenoid will have two internal coils. A strong PULL-In coil that moves the solenoid plunger and a much weaker HOLD coil that holds the solenoid retracted allowing the engine to run.
It could be that the power for the pull in coil is not working. Check for a blown 5 amp fuse.
Do you have a 12 volt test light. To do any electrical trouble shooting you need one. Less than $20 on line or any auto parts place.
Separate the power connector at the solenoid and test for power on the power connector to the solenoid.
If the connector has two terminals, test each terminal to ground as you turn the key switch from Off to ON to start
Dave
3,356
In the thread that hopefully the following link takes you to, Dave posted an electrical circuit diagram for the B7800.
This should help you if you are able to read and understand electrical diagrams...
BobbyT27
B7800
Jan 29, 2022
Ontario
Dave
Thanks Dave. I did check it across the connector. Did not realize it needs to go to ground which makes more sense. Appreciate the advice. All the fuses were good. It just seems like the solenoid gets stuck. Once I banged it it started.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,053
Thanks possibly the coil is failing then
It is far more likely you do not have power going to one side of the stop solenoid coil.
Henro posted a link to a previous thread I provided info in. Have you read through it?
Throwing $ without a thorough diagnosis will bring nothing but unhappiness.
Dave
Mark_BX25D
Bx25D
Jul 19, 2020
2,057
1,579
A bad coil that is hanging up is certainly a possibility, and the only cure for that is a new solenoid.
However, checking the electrical system should happen first. You need CLEAN connections. A tractor that old probably has some grunge. A brass brush may be all you need to fix this. Take the connections apart, and clean them shiny, apply a thin coat of dielectric grease to prevent corrosion, and see if that fixes things.
And of course, check each of the 3.2 bazillion safety switches, as already mentioned.
BobbyT27
B7800
Jan 29, 2022
Ontario
Thanks I will do that.
