B7610 hydraulic pressure
GeesBees
B7610
Dec 18, 2021
Can anyone point me to the pressure specs for a B7610? Ive been all over the web and cant find a solid answer. TIA
6,689
I assume you want the data for the implement pump and I could not find one either. What exactly are you trying to do with this information?
GeesBees
B7610
Dec 18, 2021
Just checking overall health of the machine. Almost 20 years old but new to me. I have done all the maintenance points but would like to check the pressure relief valve operation.
6,689
FWIW the LA271, LA272, LA301, LA302, LA351, LA352, LA401, LA402 WSM says 1900-2000 PSI at the loader for about half those loaders and 2100-2200 for the others. That should give you a ballpark.
GeesBees
B7610
Dec 18, 2021
Thank you. That's the "range" I was finding also. I just found it odd that I couldn't find an exact number. However it is in that range so I'm sure it's fine. Thanks again.
10,397
1920 PSI to 1991 PSI
And that is the exact numbers, it's a range not one set number.
