I have a B7200 that recently has started having a hard time starting.
Without the decompression lever engaged (no matter how hot the engine is) the motor will barely turn - or not turn at all. With the decompression lever fully engaged it will turn and if I leave the decompression lever engaged for several seconds and then push it in I can get it to fire (though usually takes several tries). Once it is started it runs fine.
Doesn't matter how hot the engine is, it barely turns if the decompression lever isn't fully engaged when starting - if anything it seems to be harder to start when warm. Up until 2/3 months ago I could start the tractor fine and didn't need to use the decompression lever (unless it was cold out).
Any ideas on what I should look at? The battery is not the problem, though I haven't tested other electrical components yet.
