Hi,
Sure could use some help - parts are getting expensive
The rubber boot and pipe assembly that covers the front drive shaft self destructed for the second time in 6 months. I replaced the brass bushing and boot about 6 months ago. Removed the shaft by punching out the roll pins, cleaned and greased the shaft where the bushing rides and added some oil to the front "U" joint assembly. Yesterday I found the pipe covering the shaft had broken at the rubber boot, the rubber boot was destroyed.
Is there anything special that I need to do / check in order to stop this from happening again?
