B7100HST Actual temperature help
Wayne64SS
'13 MX5100HST, '82 B7100HST
May 27, 2015
26
Duanesburg NY
What temps is everyone seeing on their B7100HSTs? With an infrared temp gun I'm seeing 205-212 at the top of the radiator. The bottom of the radiator is about 110ish and the cylinder head shows 210-218. This about normal? It's never whistled but I did just flush the radiator and refill and it does weep, but I'm chalking that up to overfilling. Thanks in advance
2,823
Wayne,
those numbers are right in line with what I shoot with my infrared gun too. Bottom of radiator sounds a little low, cyl head is about right. I notice that at certain areas on the head I get 5% different readings. I would NOT place 50-50 mix in there.....more like 70-30 - water to mix. Too much glycol will make it run hotter. And do not overfill, and dont leave too much air.....yeah - I know, it is a PITA to get just right........like a small baby, pukes out what it doesnt want and if you place air in it .....well - we have seen the results of that!:D:)
I am gonna place a gauge in mine soon, I need to get my crap done around here to get to that, I want to see what the fluid temps are when cutting and under load!
Keep that front end clean and you will be in good shape! I blew mine out the other day and "thought" it was clean........lots of chaff in all the hard to get to places!
6,555
85Hokie, you mention adding a gauge. In a previous thread there was discussion of dia. on interior of radiator hose on B7100, so you get the correct hose fitting for sensor. I am pretty sure it's 32MM. Can you confirm that?
2,823
yes, I bought a 32mm (I was wrong - 34 mm is the right one ) hose and the T adapter .....now I havent stuck in on the neck of the head yet!!!! But I am sure it will be the right fit - the T adapter fits very snug in the factory replacement hose.:)
Wayne64SS
May 27, 2015
26
Duanesburg NY
Good Deal thank you for confirming that for me. I do have 50/50 in it now as it was pre-mix diesel coolant so I'll drain some out and replenish with water when I add the gauge package I just ordered. Going to do temp/oil psi/fuel level out on the hood. Ordered an 18" chrome stack w/rain cap too since I flipped the exhaust to straight up. LOL The more I use this little guy the more I like it. It pulled my entire 78 F250 supercab 4x4 rolling chassis around yesterday without hardly noticing. I think I like this little guy better than my big MX, so much character.
