Bought a used Kubota B7100 with what I later found out had about 14000 hours on it, Yes you could make the argument that I was rather stupid, paid about $2200 for it. Some how it still functions even though I'm fairly certain it received no maintenance for several thousand hours. I know this because someone scratched the hours on the transmission filter when they changed it.
Anyway it has been working well and I thought the battery had gone bad because the glow plug heating indicator light would come one but barely move starter then no glow plug light, waited a few hours same thing. Batter is good, had it checked several ways. Want to pull ign. switch and check it out. Have only gotten as far as unscrewing top outside ring. Entire will rotate and if there is an inside nut holding it in place haven't figured a way to break it loose, very little distance between the switch casing and dash panel. Any suggestions short of a plasma cutter?
Thanks
Thanks
