B7100 HST problems (another one)
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
Hi All,
New member here from Wales in the UK.
Please bare with me on this one as I am new to hydrostatics, very mechanically minded, just new to HST stuff.
I bought an old '83 (I think) B7100 HST 4x4 from family, they had bought it about 2-3 years ago, used it for an hour and set it aside until they had time to fix it, they experienced the same problems as I and in the end bought a newer machine so that I could have this one.
My problems are as follows:
When I first bought it there was an issue with the trans where it would drive normally for a while, if a little loud (all my comments about running, stopping, noises, vibrations etc are aimed at the trans as the engine is near perfect) it would drive ok with revs down low, but as soon as you were on high revs it would just stop and the F/R pedal would do nothing, no noises no nothing, was like as if you weren't touching it.
You would then need to lower the revs to get it to move again, and the trans was very loud and quite often it was very jerky and was giving a lot of vibration back through the pedal, sometimes even fighting against you, then its a case of repeat the process etc.
A visual inspection through the oil filler hole showed a lot of frothing of the oil so......
I drained down the oil and found it to be full of what seemed to be ATF fluid? I took a small clean sample of it and bottled it in a clean clear bottle, fluid was red in colour and when shaken would hold a lot of air in suspension.
I removed both strainers to clean them up, what I found was that there was a lot of mulched paper type deposits on them, more on the hydraulic strainer then the HST one and some also came out when I drained the oil, in light of this I decided to leave the filter in place and strain the oil and put it back in to try to 'flush' some of whatever was in there out, tractor ran slightly better for all of about 10 minutes, where it reverted back to the same issues with stopping.
After it was warm I then drained the oil again from all 3 drain points to get as much of the sludge out as possible, allowed it to drain for a good few days while I did some other jobs.
New genuine Kubota HST filter fitted, screens cleaned again and brand new Kubota UDT back in it and it was still a little noisy but seemed to go like a rocket!! Alas it was not to last, it is a LOT better than it was but I'm still having issues.
The second time I went to use it after new fluids and filters I cou7ld not get it to move for about 15 minutes, all levers were where they should have been, so no mistakes with it being in neutral, but it just wouldn't move, pressing the pedal in either direction would do nothing, just a small barely noticeable sound if you got really close to the HST unit, this symptom is the same every time it won't move.
when it's actually driving and I'm creeping along it'll sometimes stop by itself, and I'll need to lower the revs right down to almost idle to get it to 'pick up' the drive again, sometimes it'll do this smoothly, other times it'll jerk, vibrate, bounce, fight back against the pedal or sometimes all of the above, the noise when it is fighting back is horrendous, other times it just won't move at all for a good length of time.
All symptoms happen in both forward and reverse, it makes no difference.
Other times when its driving, if I need to keep my foot on the pedal for a constant speed, it may well be fine, but if I need to stop for a split second for some reason, it goes back to the pedal not doing a thing and having to drop the revs again.
What I have noticed is that if I'm going down a slight slope, or over a bump where it makes the tractor move quicker than the trans, even if only for a split second, it'll stop all drive again.
Also from reading other posts I thought I would note the following: when it's lost drive, I can freely push it back and forth or have it roll if I'm on a hill.
I have a video of it which I'm currently uploading to youtube, I'll post the link when this site allows me to, however you can search for it on my youtube channel under "Rob Mogs"
Apologies for the quality of the video as I had a flail mower on the back in some quite heavy rushes! I can get a video without the mower running if needed.
Any help, or suggestions would be great.
Even a list of machines that use the same HST unit.
I'm no stranger to tearing unfamiliar units apart, but don't want to pull it apart if spare parts aren't available.
Thanks for your time folks.
9,153
Just watched the Video, you have something in the transmission that is damaged, I'm pretty sure it's past the HST and either in a shaft or in the range selection area.
His Video:
https://www.youtube.com/watch?v=m7TyucAMBgI
The only way your really going to know what is actually going on is to split it and look at all the parts involved.
9,153
Thanks for reply.
Cover is already off and I forgot to say that the clutch is perfect.
The issue is with the trans itself.
Reread my post, as I completely edited my post after I watched the video, that helped a lot in changing my view of your problem. ;)
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
Excellent thanks, often though when in Neutral and I press the pedal it'll make a noise, but when it's playing up and I then press the pedal in neutral it makes no noise.
If it was a shaft after the HST unit would that not have the same problem at all times?
9,153
Also if it was past the HST unit I assume I wouldn't have the pedal fighting back against me?
A stripped shaft, broken gears, striped differential, would all give you the same types of issues you are talking about and noise.
The pedal feedback is due to the load changing... a stripped shaft or other variables can do that, yes as well as an HST issue.
I'm not saying it's not the HST, to many variables to know exactly what it is.
On the HST did you change the strainer filters or just clean them?
I've seen the still clogged and restricted with just cleaning.
What type of fluid are you using?
Any weeping Hydraulic leaks on any lines or connections, as air infiltration on a suction line will also cause issues.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
Strainers were cleaned and inspected and allowed fluid to flow through them under gravity pressure.
I suspect it is something to do with the HST unit as that's where the noise is coming from and it's not a 'mechanical' noise in terms of grinding, it's more like fluid under strain bit escaping type sound, what confuses me it's when it makes literally zero effort to move, no sounds, no nothing.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
Also there's no oil leaks whatsoever from the back end, I did think air getting in somewhere but can't find anything, unless of course it's in a pipe that's higher than the fluid reservoir.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
It's very definitely a 'pump' type sound, where in one scanario it sounds like a pump straining, but in the other it sounds like a pump doing nothing at all, even though the input shaft is spinning.
I've read elsewhere on the forum (albeit for different HST models) that the charge pump fails and therefore cannot pressurise the system, I'm wondering if it could be something similar, or, and this is a long shot, a blown PRV that's randomly opening and closing, but I'm led to believe this would only affect one direction and not both.
torch
Jun 10, 2016
2,772
991
Muskoka, Ont.
From the description and video, my impression is a stripped spline on the HST input shaft/pump interface. It sounds to me like sometimes the splines grab temporarily. Continued running will probably make things worse.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
How easy is that to strip out and check? I'm assuming that it's a case of the whole unit needing to come out?
I 'may' have identified a potential source of air getting into the suction line after the strainer and before the HST unit.
torch
Jun 10, 2016
2,772
991
Muskoka, Ont.
I believe so. You can download a copy of the complete factory service manual here: http://kubotabooks.com/AutoIndex/in...df&AutoIndex=933776bb4f23cd3dc91819a6d834cef9
Definitely investigate and cure all possible leaks first. It won't hurt anything and it could well be the problem!
