B7100 Dynamo difference
Sdatrucking
B7100.
Aug 26, 2022
Tagalong3746
Still learning. Have 2 b7100s 1 has a 3 wire and other has 2 wire dynamo what’s the difference housing on 3 wire is busted will they interchange
Can I use 2 wire dynamo in place of 3 wire
10,357
The dynamo will come off the housing, if that's the part you really need.
That three wire dynamo was only ever used on the Very early B7100, and maybe the early B7001's.
I don't have a wiring diagram for the very early B7100's that took that 3 wire dynamo.
I don't think a WSM (aka service manual ) exists that shows the three wire set up.
But it memory serves me correctly one of the leads feeds the lighting circuit directly.
You could easily trace the wires back to the regulator and figure out witch 2 go there and hook those up then find the other end of wire 3 and tie it back to a switched hot for the lights.
EDIT: Little search and found it, yes it does feed the lighting circuit so my fix to turn it into a 2 wire unit will work.
Sdatrucking
B7100.
Aug 26, 2022
Tagalong3746
Thx I knew someone much smarter than me would have the answer
