gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
Wow, you were all so great about my transmission question, yes I changed the fluid this afternoon, so I have another question.
I have a loader that I am going to adapt to my B7100, my question is should I make a bracket for the existing pump and mount it to the front PTO shaft, or tap into the tractor hydraulics.
The B7100 has a valve under the seat that could provide the supply to the loader valves, I don't see a place for the return. The whole process would be much easier if I used the tractors hydraulics, I guess I am just questioning if the tractor hydraulics have sufficient pressure, reserve and flow for a loader or should I do the secondary pump to get the response I need. Also the pump that I already have is likely to fail soon and need to be replaced.
I am sure there are any number of you out there with great advice on this topic.
Thanks
Thanks
