B7000DT Tires
eventhorizon000
Kubota B7000
May 23, 2014
Delta Junction, AK
Does anyone know if I also have to change out the rims when I change rubber? I am looking at some R1 pattern tires that closely match the original rolling circumference, but have heard the rim from the cane tires is smaller than normal 16 and 12 inch rims. Does anyone know the difference? I measure the inside diameter at 16”.
Also, is the parts manual available to purchase from OTT?
8,201
Www.kubotabooks.com for the parts manual:D you just need to know what the north american equivalent is. Some one can chime in and let you know, or do an advanced search for posts on your tractor ;) not sure bout the tires.
8,758
R1's will fit on the same rims as came with the rice tires, 16" rear 12" front.
