B7000 4x4 part numbers
Corelokt
B7000 4x4
Jul 24, 2018
Duffield, VA, U.S. OF A
Help all,
New owner of an old B7000.
It needs a steering box rebuild.
I just need the part numbers to do it.
It needs a clutch, those parts I found.
It needs decals. Any source for those?
A question, the front axle has some for and aft movement, is that normal on an older machine?
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Welcome to OTT.
Have you tried looking at Messicks for the parts?
Many here use them and also Coleman Equipment Company may have what you need.
A work shop manual may be a good idea.
I just called my dealer as I bought a used tractor and the cost for a WSM printed is 100.00 and a copy on a thumb drive is 65.00. I have a means to print at no cost so I will be heading to pick one up soon.
Jim L.
870
172
Kubota B7000 is a grey market machine, that is, not made for USA or supported in USA. Once you find a part number, don't say that it is for a B7000 or that will be the end of the conversation. You might find decals on a USA model close to what you want. Or if you can't then it may be possible to make your own or have some custom made.
You can also check the parts lists on overseas.
7,136
I think the L185 is a close as you can get with most of the parts in the USA at dealers.
You might check and list your tractor serial number here so we can be sure it's not a B7100. It makes a BIG difference.
zuric
L2050DT, B7000 grey mkt. ! Workbull 202 Massey,650 John Deere, 3444 Int.
Feb 12, 2017
42
Ava Mo.
Corelokt ;
Mind posting the parts numbers or where you found them ? I have to rebuild the steering box on a B7000 4x4 myself this summer.
I found glow plugs and some decals on ebarf.
9,642
zuric
Feb 12, 2017
42
Ava Mo.
Thanks, Wolfman !..Been hesitant to tear into it because of the parts problem. Is that (low cost 4 u) affiliated with this Orange Talk site ?
