B6200 Radiator coolant hose
Groose
B6200D
Jun 12, 2015
Bridgwater UK
The hose to my water pump failed so am flushing radiator and replacing all coolant hoses. I cant find the part number to the lower hose from radiator to water pump.
The hose I need fits from lower radiator to metal water pump pipe which is a variant to the one in Water pump section of parts manual, in box noted "CA" see picture from parts catalogue.
The hose I need replaces P/N 15751-72850 But its a shorter straight hose see picture of radiator. (Bottom right)
Can anyone find this part number?
Thanks for looking.
Groose
B6200D
Jun 12, 2015
Bridgwater UK
Ahh OK.
I've been looking at the parts manual for B6200D.
I cant find parts manual for B6200HSTD in the index of Kubotabooks parts manuals.
Do you have a link?
I presume the part numbers for the other hoses are as that in B6200D parts book?
Water Pump
210 15531-72870 PIPE,WATER
Water Flange
180 15531-73350 PIPE,WATER RETURN
Radiator
310 15741-73130 Drain Hose, (supersedes PN 15531-73130)
290 15751-72940 or 15752-72940 PIPE,WATER Upper
Groose
B6200D
Jun 12, 2015
Bridgwater UK
I got a bit confused here. It appears I do have the B6200D not the HSTD.
However the water hose for the HSTD look like the right one.
8,700
Is it a gear shift B6200D
or a hydrostat B6200HSTD?
but regardless, there are always quirks to these older model Kubota's and I've seen just about every "They never did that" scenario proven wrong. :D
N3BP
Sep 20, 2016
486
213
Lebanon, PA
Wolfman, do you think he has a Canadian 6200D? If you notice in the first attachment he sent there is a little "CA" which I think means it's specific to machines sold in Canada, eh?
Groose
B6200D
Jun 12, 2015
Bridgwater UK
Its a gear shift.
I have since discovered the hose part i need is Canadian version. Both US and Canadian versions available in the UK and probably the same part but happily the Canadian version is half the price.
