Hi all,
So I have an ongoing project of a B6100D with a home made loader, that was done by the guy I bought it from.
The loader was originally run from a battery connected hydraulic pump. I removed this, and plumbed in the FEL using the stock hydraulic pump and a new valve that had Power Beyond (with much thanks to the people here for talking me through it).
The transmission is my reservoir, and the fluid looked like milk. I flushed it a lot and put in new fluid, and it looks decent.
I finally got it all hooked up today and did some driving around, and in the course of 20 minutes the throw of the clutch went spongy. It went from normal engagement, to only engaging at the very end of the travel of the clutch pedal.
No grinding or anything, it works fine otherwise. Same in high or low.
I can look up how to adjust the clutch, but what I am looking for advice or knowledge on is why it changed halfway through use. Any ideas? Do I need to flush the fluid again? Is it just needing an adjustment?
Much thanks
Much thanks
