B6100 HsT
acoffma3
B6100 Hst
Apr 8, 2020
North Benton Oh USA
B6100 HsT pedal forward and tractor goes backwards and vise versus
Drove b6100 into garage as normal decided to change hydraulic screen filter and fluid. Put super udt fluid and kubota screen and filter on. Touched nothing except the 2 drains and screen and filter once put it back together the pedal forward makes it go backwards and backwards make it go forwards. Called 6 dealers and they all have no clue. Anyone ever seen this?
5,181
Re: B6100 HsT pedal forward and tractor goes backwards and vise versus
Only seen this when the engine is run backwards.
I've never heard of that issue.
I'm wondering if you just got unlucky and the neutral adjuster was loose and flipped over some how???
5,181
Ok thanks I’ll look that today. According to the dealerships motor isn’t running backwards.
Yea, I should have said, that the motor running backwards is VERY VERY VERY rare and normally something else causes it to happen.
Tnkubotaguy
Kubota 1700
Jun 27, 2021
24
Nashville
I got the same problem, used rhe same fluid you did and changed the filter, now rev is fwd and fwd is rev. What was the fix?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,115
Hardisty, Alberta
Looks to me like someone else removed the wrong plug and allowed the motor reaction plate to turn.
Tnkubotaguy
Kubota 1700
Jun 27, 2021
24
Nashville
But i dont think my reaction plate moved, unless it's spring loaded to immediately invert once the bolt is removed.
So it looks like i either live with it or disassemble and invert the reaction plate?
eserv
May 27, 2009
2,115
Hardisty, Alberta
It is not directly spring loaded but the pistons are. Depending what residual oil pressure would be in there and what it would take to balance the springs on the pistons, that plate could rotate when the pin was removed. I honestly can't think of any other thing that would make your tractor operate like that!
Tnkubotaguy
Kubota 1700
Jun 27, 2021
24
Nashville
Well...i hope for my sake, somebody else can think of a reason as taking that pump apart to invert the reaction plate and risk breaking something else is not worth it.
eserv
May 27, 2009
2,115
Hardisty, Alberta
Just for interest sake how level was the tractor when you first removed that pin and was the main transmission in gear or not?
Tnkubotaguy
Kubota 1700
Jun 27, 2021
24
Nashville
I would say pretty level and no idea if in gear or not as that was not a concern for me as all I wanted to do was change the filthy tranny fluid. I did that and now have a backwards tractor.
eserv
May 27, 2009
2,115
Hardisty, Alberta
I was trying to determine if there was any torque on the motor section when the pin was removed
Tnkubotaguy
Kubota 1700
Jun 27, 2021
24
Nashville
Well...if this is indeed what caused everything to reverse flow then there must have been. I'm still hoping somebody chimes in here with an easy fix or ingenious pedal modification that makes it go forward when I press the treadle plate down in the front.
