Hi
Bob here
Inherited 1970 B6100 Kubota diesel.. Fan belt shredded and needs replacing. This machine has a hydraulic PTO shaft in front. I assume it and the shaft must be removed before replacing the fan belt.
Is there an issue with pressure in the unit once removed. It has two hydraulic lines running to it...
Will the shaft just slip out after front bolts are removed?
Also rear brakes are frozen open.. Can they be loosened manually if rear wheels and shroud is removed? Any attempted this before?
I have reviewed owners manuals and parts diagrams but no advice on repairs to these items..
If you have any info .. It will be most appreciated. The tractor ran well before fan belt failure Would like to give new life back into this relic.
Thanks
Bob here
Thanks
