B6100 drive shat u joint replacement
joezzz
B6100
Jan 3, 2013
essex, CT
I have developed a sound in the driveshaft tube going to the front differential
By moving the tube the sound goes away. Is that a sign of a worn U-Joint?
Any suggestions? Any tips on how to replace U-joints?
8,790
The only way to know what is causing the issue it to take it apart and inspect parts as you go.
Tip one to any repair is get the repair manual aka WSM, you can get it on Kubotabooks.com.
2,838
I am confused - so you go under the tractor while off and "move the tube" and start it back up and the sound goes away? I take it - the sound comes back after a bit?
What type of sound? Metal to metal? or squealing or? clank clank?
NIW posted this a while back - excellent help
https://www.orangetractortalks.com/...-front-drive-shaft-removal.23647/#post-193125
joezzz
B6100
Jan 3, 2013
essex, CT
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Well if it's like the M series, shift the tube back, drive the roll pin out of the collar, repeat on other side, move collars and drive shaft could be something wobbling
