smokinhart
b6000E,B6100DT, King Cutter RM48, Front end Loader, Rear Blade,Gravel Reclaimer
Just dug into the right side brake cover on the b6100 tonight to find the problem of why the right brake would not grab. The differential axle shaft drive coming up to the brake drum is broken directly behind the drum.
I looked in WSM but found nothing for advice. Maybe Vic or someone can tell me if I have to go into the differential to remove and replace this shaft or if it can be pulled from the cover and bearing side against the axle shaft. In other word is there any retainer clip deep inside the diff case or is it in a bearing sleeve at the back of the shaft so that when I replace the shaft and outer bearing it can just slide in place and mesh in with the axle drive?.
Help. Its February and the tractor rebuild is dragging out way to long. Of course I just fabbed and installed the loader subframe and it will all have to come off just to start into the diff cover .
Even any words of encouragement here guys.?
