B5100E Draw bar
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
237
253
Pennsylvania
Where can I find a draw bar for this tractor, used, new, bent...no matter, I need it.
3,008
you are talking the straight slide in piece that a pin holds in place? or the 3 point bar?
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Hello arml,
I went through the owners manual and cannot find a specific reference to the draw bar. It should be around page 34 where they talk about the three point hitch. It appears that there is a "tow point" (appears to be a clevis hitch) but not a "draw bar receiver".
Send me a message (upper right hand corner of the page) and I will send you the manual. It is too big to post.
arml
Jan 27, 2022
237
253
Pennsylvania
Hello arml,
Thanks for the offer, I do have the parts manual, could not find it either.
Thank you for your service.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
You can send 007kubotaguy (Lance) a pm to see if he has one.
You can also purchase it by measurements on eBay or an ag supplier.
Make one out of mild steel bar stock with a band saw and a drill press.
fyi, I made mine from an old Reese trailer hitch I found under a workbench
Strongly recommended not to use the 3pt style beyond lightweight, empty, flat yard jockey duty.
kubotasam
Apr 26, 2010
1,211
136
Alfred Maine
Yes, the slide in bar.
I do not believe that a B5100 was designed to accept a slide in drawbar. They are built like my B7100 and they have a built in hitch on the back but not moveable or extendible. b5100.jpg
19thSF
Mar 1, 2020
408
123
I do not believe that a B5100 was designed to accept a slide in drawbar. They are built like my B7100 and they have a built in hitch on the back but not moveable or extendible. View attachment 74178
After looking through the manual, that was my comment. It is a clevis hitch tow point.
3,008
" They are built like my B7100 and they have a built in hitch on the back but not moveable or extendible. '
Not sure if you are talking about older or newer B7100 - but all of mine B7100's have the slide in, pin locking draw bar. But I have seen the same diagram as you.
arml
Jan 27, 2022
237
253
Pennsylvania
Thank you for your reply,
Yes, I see in the diagram that you are correct. I've not gone to to look at that closely, memory serves me it sure looks like that. Tractor is parked across the far field shed, we just had snow. My old bones do not want that walk for now. Thank you for that diagram.
