B3200 Block Heater
Tughill Tom
B3200
Dec 23, 2013
1,109
1,124
Turin, NY
Hi all,
New to the Kubota world, Just bought a 2011 B3200 with loader and front mounted snowblower. I'm looking to install a block heater with and outside temp. controller to turn it on and off. Any such thing out there?
Thanks,
Tom
Tughill Tom
B3200
Dec 23, 2013
1,109
1,124
Turin, NY
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
306
77
Bagley, MN, United States
The 'Thermo-Cube' turns the outlet on and off at the preset temperatures - it will control whatever you decide to plug into the 'Thermo-Cube. Whatever type of heater that you decide to install will plug into the 'Thermo-Cube' receptacle. I use one to turn on a milk-house heater in my pump-house at 35 degrees f and turn off at 45 degrees f. I believe that it will work with any 1000 -1500 Watt block/tank heater that you want to install. I also read some reviews that some people have had issues with these units but mine has worked okay for me so far.
kuboman
725
Thanks, I saw one of those at Tractor Supply today. How about the heater it self. Does it mount in a freeze out plug? Thermostat area?
There is a large screw in plug on the left side of the engine towards the front of the engine. It is a screw type block heater not the front plug style.
