Well have installed new clutch and inspected shaft to hst/charge pump with no change. Tractor is 4wd with loader will work in every gear but over the summer and this fall has gotten to where it will go one direction then when you change direction it sits like its in neutral and then slams into motion like your dumping the clutch.
Also doesn't have the speed that it should but low med and high obviously are different speeds and work as such. In high it sounds like it screams then starts to move then starts to get up to speed. Needing advice/knowledge from HST experts
