B2650 front quick hitch
tb82
Worthington, MN
Hello! I have the opportunity to buy a front mount broom with all attaching hardware for a reasonable price. My question is if any of you know, or can tell me how to look up, whether a B3030 and a B2650 would have all interchangeable mounting parts for the broom/snowblower. So the front quick hitch, PTO kit, mounting hardware... and what is the support kit for the hitch? A dealer told me I’d need to order a support kit as well if I ordered new. Thanks for any help!
200mph
Mar 3, 2017
1,228
65
PA
Notes from Wholegoods 2015.
For B2781B snowblower:
Quick Hitch B2791A, (B2650HSD, B2650HSDC, B3350HSD, B3350HSDC) - Requires Quick Hitch B2714B & Mid-PTO Driveline B2793 (CAB)
or B2747(ROPS)
For B2779 sweeper:
(B2650HSD, B2650HSDC, B3350HSD, B3350HSDC) - Requires Quick Hitch B2714B & Mid-PTO Driveline B2793 (CAB) or B2747(ROPS)
B2776
Quick Hitch Frame Support Kit Necessary for when the B2301/B2601/B2650/B3350HSDC tractors that do not have a loader subframe
Hope this helps.
It would help some if you posted the snowblower and sweeper models you're trying to purchase.
nbryan
Jan 3, 2019
1,363
889
Hadashville, Manitoba, Canada
As far as I know the snow blower, broom, and a blade quick attach to the same hydraulically elevated sub-frame. That sub-frame also carries the mid-pto drive extension shaft for the blower and rotary brush.
So if you get the broom and all attaching frames and hardware then yes, you can hook up a snowblower or blade to the same frame. The blower would need its own telescoping drive shaft to connect to the frame output shaft.
I have a hydraulic chute deflector control which used the bucket curl circuit on the loader valve. I assume you have a front loader.
