B2601 Not Starting
Plant 175
Kubota Sidekick and B2601
Jun 3, 2021
141
70
Wisconsin
I took my tractor out of the garage today and hosed it off and now it won’t start.. I wasn’t using a pressure washer washer just a hose. I’m tarped it and will go back up Friday to see if it starts. Any idea what could have gotten wet and made it not start.
Thanks
11,268
Possibly you bumped a lever when you washed it.
Check all levers especially the PTO and rock the HST pedal back and forth while trying to crank it.
5,566
It would also help to be a little more specific on the symptoms.
Was it a "crank-no start"
Or was it a "no crank-no start"
It kinda makes a big difference in the troubleshooting procedure(s). (y)
Plant 175
Jun 3, 2021
141
70
Wisconsin
No crank at all but the fuel gauge go up when I turn the key. I checked the battery all connections are tight.
5,691
If I was a betting man I would say you bumped the PTO lever, which is a safety switch and will not let it start
5,566
Sounds exactly the same as when my grandson flips the PTO switch on me. ;):)
Plant 175
Jun 3, 2021
141
70
Wisconsin
Started raining to hard so I didn’t go up today and try it
Well boys and girls I got my tractor started today. Not sure but have a sneaky suspicion my PTO was slightly engaged like Scissors said could be the problem. Any way that you all for your suggestions.
