D dholt53 Member Sep 29, 2015 31 1 8 73 Gasburg Jan 28, 2026 #1 How can I adjust the hydraulic pressure on my B26?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,408 11,202 113 Sandpoint, ID Jan 28, 2026 #2 There is mutiple hydraulic systems on that tractor. What do you want to accomplish? You can use the WSM to adjust it.
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, G2160/RCK60, G2460/RCK60 Apr 6, 2021 12,916 7,327 113 Myersville, MD windyridgefarm.us Jan 29, 2026 #3 dholt53 said: How can I adjust the hydraulic pressure on my B26? Click to expand... Why do you think it needs to be adjusted? Dan
D dholt53 Member Sep 29, 2015 31 1 8 73 Gasburg Feb 2, 2026 #4 TheOldHokie said: Why do you think it needs to be adjusted? Dan Click to expand... I’ve re sealed both the boom and stick cylinders and it it still doesn’ doesnt have the lifting power it should have . It’s a 20199 model with dholt53 said: How can I adjust the hydraulic pressure on my B26? Click to expand...
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, G2160/RCK60, G2460/RCK60 Apr 6, 2021 12,916 7,327 113 Myersville, MD windyridgefarm.us Feb 2, 2026 #5 dholt53 said: I’ve re sealed both the boom and stick cylinders and it it still doesn’ doesnt have the lifting power it should have . It’s a 20199 model with Click to expand... Check the pressure before adjusting anything. There are multiple possible causes and you need to test at multiple places to determine where the problem actually is. Dan
