B26 diff and trans repair
Lanewigs
B26 and B21
Jan 9, 2022
PA
All,
I have a B26. The pinion bearing went out and trashed the diff and a few things in the range gearbox. I’ve completely gone through everything from the flywheel back. The hyd tank was full of bearings, filings, etc.
Of course, that tank and the drive train are now spotless. My question is - does the hydraulic filter system have the ability to bypass the filter? I know that the motor oil systems in a car will bypass when cold or the filter is plugged. I’m trying to determine how much of that trash made it past the filters and into the pump and related cylinders/steering. Theoretically it could be none (if no bypass) or a ton if they can bypass.
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
I believe they(filter) will bypass. They need the capability when cold…But keep in mind that filter is made to take in a good quantity before it is plugged. You may be lucky.
9,373
No hydraulic filters and systems do not bypass!
What good would they be if they let contaminated fluid get to the pump and valves.
The filter should have saved the pump and valves from damage.
But if the element in the filter was plugged to the point of crush then anything could have gotten by it.
Lanewigs
B26 and B21
Jan 9, 2022
PA
Thanks. The filter was not crushed. I will cut it open tonight and see how full it is.
