It would be pretty hard to get heat from it if I had a cab on it! This could be an issue down the road when I do get one
There are several things you can do to increase the engine temperature for better performance and more heat to a cab:
1. Use a block heater – The tractor will start better and come up to temperature faster. After using the block heater, by the time I allow the tractor to warm up 5 to 10 minutes I have heat coming out of the heater.
2. Block off some of the radiator air flow – On my BX the radiator cooling inlet is under the steering wheel and inside the cab.
I block it off to reduce air flow through the cab and to the radiator.
3. Pipe the heater to the radiator bypass – By using the bypass for the heater you have heat as soon as the engine starts warming up.
4. Load up the engine – Snow blowing and snow blowing heavy snow or more than a couple of inches of light snow, I can load the engine to the point I have to slow down to maintain engine rpms. With the engine fully loaded it will put out heat.
