D Doug G New member Equipment Kubota B2150HST Aug 14, 2019 1 0 0 Sussex,wi. Aug 14, 2019 #1 Battery is strong but wont turn over. bypassed safety start.Could it be in electric solenoid? It clicks when key is turned. Happened once before and suddenly started working again.
R RCW Well-known member Lifetime Member Equipment BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU Apr 28, 2013 10,324 7,346 113 Chenango County, NY Aug 14, 2019 #2 Most times it's still the battery. It looks/acts strong, but just can't throw enough amps to roll it. Have it load tested at an auto supply to verify. Other times it's a bad ground or other connection. Make sure all connections are bright and tight. I would start there to rule those out before further troubleshooting. Good luck!
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 14,989 7,675 113 40 miles south of Kansas City Aug 14, 2019 #3 Be real sure your battery ground wire to the frame is clean at the frame and in good condition. That's what usually gets overlooked.
