B2150 wont start
Doug G
Kubota B2150HST
Aug 14, 2019
Sussex,wi.
Battery is strong but wont turn over. bypassed safety start.Could it be in electric solenoid? It clicks when key is turned. Happened once before and suddenly started working again.
7,017
Most times it's still the battery. It looks/acts strong, but just can't throw enough amps to roll it. Have it load tested at an auto supply to verify.
Other times it's a bad ground or other connection. Make sure all connections are bright and tight.
I would start there to rule those out before further troubleshooting.
Good luck!
6,877
Be real sure your battery ground wire to the frame is clean at the frame and in good condition. That's what usually gets overlooked.
