B2150 Ag.Tires
modeladay
Sold B7100 and purchased a B2150 with FEL
Mar 25, 2016
117
10
Lincolnton, GA
Tractordata shows 6.00-12 tires for front wheels. Many other places Say 6-12. Kubota tech says there's no difference. Guy I bought the 6.00-12 tires from says they're 2 inches taller. I'm I stuck with tires I can't use? Is there someone out there with a B2150 that has the Ag tires that can look to see what size they have.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
It's a B2150D. For future reference, that's from my profile, also under my name on the left. Anyway, yes, it's 4WD. I'm not sure exactly what the tires came off of, I bought them as take-offs, but I believe they are the right size for the B2150D, and I have no known issues using the 4WD.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
Russ I have looked everywhere and I have never seen that size listed for a B2150, doesn't mean it's not right I just haven't seen any. Anyway I really still don't know if I got the right tires, this shouldn't be this hard and unfortunately I got a lot of money invested. Thanks again.
BadDog
Jun 5, 2013
579
Phoenix, AZ
Give it a bit for the old hands to drop by. We've got several here who know their way around the in's and out's of tractor tires. They helped me work out what would work, and also eventually make the connection that landed me the tires. They will know how to answer your original question directly.
11,141
The right tire is a 6.00-12. ;)
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
I got the new Ag tires and wheels mounted on the tractor today, I got a big surprise when I pulled the rear off. I was not expecting it to be liquid filled:eek: It almost landed on my leg.
Does anyone know how much liquid a 12.4-12 tire can hold? I'm thinking of a way to transfer the liquid in the turf tire to my new Ag tires. Also anyone looking for a set of Ag wheels and tires for a B2150 let me know....rear tires aren't that great but the fronts are pretty good
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Don't know if you ended up getting the correct tires or not but here's some
information.
A 600-2 and a 180/85D12 are both the same size tire in rolling circumference.
The 6-12 is to small and will cause you problems. If memory serves me correctly since neither the 600-12 or 180/85D12 are no longer available the 7-12 R1 in
the Goodyear brand ( NOT BKT!!! ) is the same rolling circumference.
The 7-12 BKT is WAY to big not even close in rolling circumference.
Al
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
information.
Al
Thanks, yes I did find 6.00-12s and put them on and the tire guy I purchased them from said they are 2 inches taller than the 6-12s I have not seen or felt any binding as of yet. Hope it's all good
WildWilt
L4600 & B2150
Jan 19, 2022
Redding, CT
my B2150HST 4WD owners manual says Front: 6-12 with Rear: 12.4-16. R-1 AG tires. while both tires look similar, the 6-12 tire has a 4.00D rim width, whereas the 6.00-12 requires a 4.50E rim. The outer diameter is also different, with the 6-12 being about 23 inches and the 6.00-12 being about 24 inches. Outer diameters do seem to vary by tire brand
