B21 Front axle oil question
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
Not sure if the B series varies from the BX series, but the BX has a dip stick on the left side as your sitting on it. The BX book calls for 80w-90 or Super UTD fluid.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum.
This is what Kubota shows:
KUBOTA UDT or SUPER UDT fluid* or SAE80, 90 gear oil
2,976
What is the correct way to check the oil level in the front axle on my B21 and what is the fluid type to be used etc?
Ask other Idaho operators.......and there are several! I would say in the winter, you will want a S-UDT2 in there. 80w90 might be a bit "thick" when you want to go plow some snow ....when the temps hit single digits! Where as S-UDT2 will pour somewhat like water at those temps. ;)
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
And don't forget to check with the tractor reasonably level...and if you haven't checked the torque on the pivot bolt now is a good time. Mine weeps quite a bit on the pivot.
-Mac
10,194
B21, UDT or SUDT will work great.
Dipstick on the right hand top. ;)
